Topic: Recording digital input on ADI2 Pro in DAC/USB stereo mode
I am enjoying my new ADI2 Pro unit. One thing I found different from my older ADI2 DAC unit is that recording seems to be locked to 'Analogue input' when the unit is in USB stereo or DAC mode.  I need to record in channel 1+2 due to the application only supports two channels. Is there any way to select which inputs to record (like Rec Coax in the DAC unit)? Thanks.
2 (edited by ramses 2020-07-16 05:50:45)
Re: Recording digital input on ADI2 Pro in DAC/USB stereo mode
See manual
- 14.1.3 Device Mode, CC-Mode and
- 17.4 Class Compliant Multi-channel mode.
Yes it would be able to record in multi-channel mode but my application can only record from channel 1 and 2.
There is no way to fix that other than using an app that can use other channels as well.
