Topic: SRC on AES out
I am using ADI 2 Pro FS to connect to monitors with digital input. The source signal comes from USB or coax SPDIF. Is it possible to always do SRC regardless the input sample rate so that AES outputs at 192k?
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → SRC on AES out
The SRC only works for AES/SPDIF input. So for USB you have to find a different (software) solution.
Is this a hardware limitation or a question of internal routing?
My question aims at using a higher internal sample rate ("upsampling / oversampling") which I found slightly beneficial with EQ treble boosts.
A fixed output SR might be favorable for other situations too, e.g. feeding a recording device.
