1 (edited by terids 2020-07-30 13:09:31)
Topic: ADI-2 DAC FS 32-bit audio on Windows 10?
Just received this device and been through the manual.
When I first connected it to the PC on Windows 10 (via USB), I could select from a list of 32 bit output formats 192kHz and above.
I then installed the driver from the RME site, and updated the firmware to latest. Since then I only get 16 / 24 bit and 192kHz, either 1 channel or 2 channel. (So 4 options in total).
Where exactly did all the other options go, and how do I get the 32-bit option back?
I've tried uninstalling the driver, but seems these are the only options it's giving me now sad
Re: ADI-2 DAC FS 32-bit audio on Windows 10?
It’s the same for me.
Install asio driver, then which ever player your using...... jriver . Foobar ect
Select asio driver.
You should then have pcm up to 768khz and dsd capability.
Does installing the asio4all driver let you select 32 bit sound in Windows 10 again? Is there any advantage to that vs. the 24 bit default you have after installing MADIface (which limits to 24 bit)?
