Topic: Auto change EQ preset based on input
Im sure this has been asked, but is it possible to assign an EQ preset to each type of input?  I use a different EQ curve for OPT and USB inputs. It would be cool if the change could be done automatically.
Thank you
Magnepan 1.7i,  Luxman 509x,  RME ADI-2 DAC,  RPI4 Streamer
2 (edited by KaiS 2020-08-11 18:37:39)
Re: Auto change EQ preset based on input
Yes!
If you use a setup for each input configuration you can have all DSP functions switched at once, together with selecting the input config that is stored.
3 (edited by daleberlin 2020-08-11 16:04:38)
Thank you very much Kais, I appreciate your feedback.   I am sorry, but I still don't understand how to accomplish this.  Let me say exactly what I am trying to do:
(I/O | Line Out | Settings | Source) is set to AUTO
I have saved the settings I want when listening to music via USB input, into Setup-1
I have saved the settings I want when watching TV via the SPDIF optical, into Setup-2
I would like the RME ADI-2 DAC FS to automatically load either Setup-1 or Setup-2 based on which input is being used.
Is this possible?  If so can you please give me details.
Thanks you
No, you load Setup 1 or 2 to switch between the inputs. Including EQ then.
Thank you
