Topic: my adi 2 pro fs has crackling & noisy sound issue.
I've already sent email about this issue over a year ago.
but I didn't get any direction of help. so I write this here again.
over a year ago,
weird sound issue start from my adi 2 pro fs.
on windows 10 pro,
usb connection,
normal usage with 24bit, 192khz, usb mode(auto) or dac mode.
sometime, randomly sounds being crackling, noisy and teared on just playback.
there is only way being correct is off&on again adi 2 pro fs or dis/re-connect usb cable.
I've try some ways to fix this,
1. add fan for cooling -> still same.
2. adding usb repeater with dc power -> still same.
- not using anymore after change to shorter usb cable.
3. change to shorter usb cable (maybe 1.2 or 1.5m from 1.8m or 2m) -> still same.
- I cannot use any shorter cable by limitation of my hardwares position.
4. add heatsink inside(chipsets on pcb) and outside of adi 2 pro fs -> still same.
- I know, this meant to be breaking warranty, but I had to do anything for fixing...
after all of these history of trying, sound issue still happen, but lesser maybe.
the time when it really being crazy, issue was happen 2~4 times in a day.
but now, 2~3 times in a week..
now only few methods are remain that I could try
- add aluminium emi shield tapes on usb cable surface
- add usb filter/isolator from Intona?
or is there any solution to fix this?
I'm being heavily tired about this now...
