Topic: Digicheck 5.93 and Babyface Pro
Greetings,
I'm on Windows and the last digicheck version doesn't work for me.
I've tried Uninstall/Install, Restart/Shutdown PC and plug/unplugged Babyface Pro.
If I install 5.92 everything works again.
Is this version supposed to just work with the upcoming driver for Babyface Pro?
(I'm speculating because I don't know what I'm doing wrong)
Re: Digicheck 5.93 and Babyface Pro
5.93 works over here with all our interfaces. What exactly did not work?
The application opens and I set it to Totalyser with the same settings as previous version and nothing happens.
The only way I got it to work was to open Digicheck 5.92 and then click on 5.93 and choose Totalyser, if I do this the last version works but if I open only 5.93 nothing happens when audio is going through it.
Issue recognized and fixed. Download 5.93 again and install it over the existing one. Or use a file manager, go into the RME\Digicheck5 program folder, then rename Digicheck.exe to digicheck.exe.
Thank you MC for the fast fix!
I've downloaded again and it works like a charm!
