Topic: ADI-2 Pro FS R and Genelec Signal Sensing Feature
I use a ADI-2 Pro (FS R Black Edition) connected via Analogue Out (XLR) to a pair of Genelec 8040B monitors.
The Genelecs have a feature called ISS, i.e.:
Intelligent Signal Sensing. This automatically powers the monitors down to standby mode after a certain time when playback has ended. This feature worked well with my previous DAC (Resonessence Invicta). Now comes the strange thing:
Situation 1)
ADI-2 Pro is powered on (white light ring around the power button), no input signal for ca. 50 minutes:
the Genelecs go into standby mode (as expected)
Situation 2)
ADI-2 Pro switched off (red light ring around the power button), no input signal since any time longer than 50 minutes: the Genelecs remain fully powered on.
In addition, I did this test:
Situation 1). Waited until the Genelecs went to sleep (green LEDs off). Now I switched off the RME ADI-2 Pro (so that the red light ring occurs). After less than one minute, the Genelecs woke up (green LEDs on).
There must be something going on at the balanced outputs of the ADI if the unit is in standby mode (red light ring), that prevents the Genelecs from going to sleep. Any thoughts and hints would be greatly appreciated.
