Topic: ADI-2 PRO as Audio Interface together with external Preamp
Hello :-)
Up to now, i have always used my ADI-2 PRO only for making music with VST plug-ins. The ASIO driver made this possible. Now i want to connect hardware synthesizers and use the ADI as A/D converter. If i understand this correctly, can i connect the ADI to other preamps via ADAT and use the connections of the preamps here? Also some interfaces can be used just as input boxes through ADAT, someone told me. Which preamps are recommended here? It is important for me not to spend so much money anymore, since the ADI does the conversion, could these also be cheap preamps? I need an advice here..
EDIT: I want to connect 2 or 3 Synths. Atm i have a Novation SUmmit Synthesizer and it is planned to buy a MC 707 which transfers Ausio over USB aswell.
