Topic: OSC Command to move to a specific channel ?
i want to put a button on an OSC layout which moves the selection to a specific channel, is this possible ? or is the only option to make a button with 2/track+ and press it multiple times to move to the desired channel ?
I saw the option for select/1/4 but when I tried this pattern it just selected the fader of that channel and not the actual channel itself.. so you cant change EQ and FX controls like you can when you cycle through them using 2/track+
I also saw the setSubmix pattern but I didn't have any luck getting this to work ? I want to select channel 4 on bottom row.. if setSubmix would do what I am looking for, does anyone know how would I use it on an OSC button ? I added setSubmix/4 but it didn't work ??
