Topic: USB Re-clocker/Regenerator
I just purchased the ADI-2 dac and wanted to know if the forum think you need to add a USB re-clocker/regenerator before the USB input on the ADI dac (i.e. microrendu, etc.).  I using a mac mini, Raspberry pi 4 with Ropieee into the ADI dac.
If you think a re=clocker/regenerator would be helpful, what unit would you recommend?
Thanks for your help.
Greg
Re: USB Re-clocker/Regenerator
No.
Unequivocally "NO".
More info here: https://www.rme-audio.de/steadyclock-fs.html
Rune Borup @ FishCorp
Producer / Engineer / Composer
RayDAT > 2 x ADI-8 QS | AES+SPDIF > ADI-2 Pro
4 (edited by KaiS 2020-12-12 21:25:35)
No, this function is already built into ADI-2, called "Steadyclock FS".
Doubling it doesn't improve anything.
If something is already straight you cannot straighten it more.
Sidenote:
Same applies to esoteric expensive USB cables, there is no improvement whatsoever that can be gained from them.
