I've not been looking for errors since the BSOD's occur when the DAC is powered off after playback is paused for ~an hour or so but I will.
A few hours ago I started retesting my DAC in the system where the other DAC did not fail (call it "original system") - I should know if it works or dies in a couple of days. That said, I have been testing my DAC on a newly built machine ("new system") and I've learned that it will likely continue to crash the original system since its had a half-dozen BSODs from 12/20 through this morning on the new machine.
Since there are no tests, I would appreciate any thoughts you might have about how to nail this down - its getting expensive and I might be better off buying another DAC. Below are specs for equipment involved along with the 'evidence' relating the BSODs to the DAC.
The ADI-2 DAC FS Firmware Version is 34, USB version is 34 and USB driver is version 0.9734. The DAC is always connected via XLR to a Stax SRM-700T amplifier, but mostly I use it as a headphone amplifier for a variety of headphones so the Stax is rarely powered on. I use the RME ASIO driver with Roon to feed the RME.
The two computer motherboards are:
ASUS Strix Z490-E ATX MB, 64.0 GB dram, Intel i7-10700K CPU
ASUS Strix Z390-I ITX MB, 16GB dram, Intel I5-8600K CPU
Windows 10 on both is identical:
Both of these computers have upgraded motherboards, done to eliminate them as a source of error. Similarly, RME has updated the driver to correct possible issues with surprise removal while using ASIO. This seems to have changed the character of the BSODs in that they occur under different circumstances and there is little evidence about what caused them. In short, its taken longer for me to find evidence that the RME is related to the changed character of these BSODs aside from me observing that it occurs when powering off the DAC.
Evidence: The mini and full memory dumps have the RME ADI-2 DAC’s Device ID, highlighted below, in them.
11: kd> !blackboxpnp
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 132541634141963316
PnpEventInformation: 3
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : USB\VID_2A39&PID_3FD3\C03A01B44E7C2C8
VetoString :
Using msinfo.exe, the DeviceId maps to:
• Name: RME ADI-2 DAC
• Manufacturer: RME
• PNP Device ID: USB\VID_2A39&PID_3FD3\C03A01B44E7C2C8
• Driver: C:\WINDOWS\SYSTEM32\DRIVERS\MADIFACE_USB_64.SYS (0.9.734.0, 286.26 KB (293,128 bytes)
Note: I've only seen this in the new system and will be looking for it in the original system if it crashes. Will this be helpful to RME?
Thanks in advance.
