Topic: 2 Digiface USB on 1 computer
When I hook up 2 Digiface USB to 1 Computer, do both Digiface share 1 Totalmix ?
Or are there then 2 Totalmix and I can't route signals between those 2 Digifaces ?
Wondering...
RME User Forum → FireWire & USB series → 2 Digiface USB on 1 computer
Wondering...
You can switch between device 1 and 2 or use a TM FX window/instance per unit, as you like.
But you can route channels only inside of an instance.
Devices need to be synchronized and on Windows you need to set both devices to the same ASIO buffersize.
On macOS you can create an aggregate device which you can then select as one interface in your DAW.
From your DAW you will then be able to route to any channel of the connected interfaces.
However, you will still have to deal with the two instances of Total Mix and are not able to route in between the two interfaces in Total Mix itself (unless you run optical cables between the two interfaces of course).
