Topic: ADI-2 DAC FS - Possible to disable the DAC?
I have an ADI-2 DAC FS and have the following question:
1. Is it possible to disable the DAC? Or do so selectively based on configuration?
I am going to be using it as a DAC & preamp for my main audiophile stereo setup, which is:
Laptop (Source) via USB -> ADI-2 DAC FS (DAC/volume control/room correction) -> Class-D Monoblocks via XLR -> passive speakers.
I'm ALSO possibly going to use it as a volume control for my PC audio/music studio setup, which would be:
Laptop (Source) via USB -> ADI-2 DAC FS (volume control ONLY) -> AES/EBU converter -> Genelec Active Speakers via digital input (using the active speaker's internal DAC and amp). Room correction done with Genelec GLM.
It should be possible to use the ADI-2 DAC FS for both configurations above right? If so, for the 2nd config above, would I need to disable the internal DAC on the ADI-2 DAC FS? I wouldn't want it to do double DA conversions going through 2 DACs.
Or, what if I want to some day use the 1st config above except use a different, external DAC? Could I disable the internal DAC?
Thanks in advance.
