Topic: Need help to setup ES9 Expert Sleepers with Fireface USB 802
Hi Guys, i need help to setup the Fireface for the ADAT, i would like use the es9 adat and the fireface usb with the daw Ableton, let me know,
thanks
Re: Need help to setup ES9 Expert Sleepers with Fireface USB 802
These are totally separate audio interfaces. Checking the es9 it does not have adat only spdif. I’m not sure what you are trying to do. I think you need to say exactly how you would like to use these. Does Ableton support the use of more than one audio interface?
abeton supported only one audio interface, anyway  expert sleepers have adat
Fireface settings clock source set to internal.
ES9 clock setting to external adat In, may be there is a switch or a jumper ?
The user manual has no word of samplerate kHz, this looks like neverending DIY-Baustelle.
I think you'd better get rid of it.
Hook up the toslink cables and see if you get signals.
M1-Monterey, Madiface Pro, Digiface USB, Babyface silver
I went on what I found in the manual. Is an expert one different? I’m guessing it is.
