1 (edited by dannyzen 2021-02-24 18:25:49)
Topic: Linux / Manjaro & MacOS Catalina: 0 bit tests passing
Linux Setup:
Linux 5.4.97-1-MANJARO
Using VLC (3.0.12) for bit test playback. Directly wiring in (USB -> ADi-2 DAC fb)
$> lsbusb
Bus 001 Device 013: ID 2a39:3fd3 RME ADI-2 DAC (59920649)
Mac Setup:
Catalina 10.15.7
Playing through Music App
Sound is output & cleanly audible, would like to get bit tests to pass. Any calibration ideas or additional information I can provide?
Re: Linux / Manjaro & MacOS Catalina: 0 bit tests passing
Is volume at 0dB (check music player and any mixer devices).
Yes, it is.
Sorry no further idea.
What interface is VLC using?
ALSA? Jackd? Portaudio?
6 (edited by fisico 2021-02-24 23:39:27)
No comments for VLC on Linux
Music on Catalina should play bit perfect. Check: 1) Volume at 100% (done), 2) Uncheck "Sound Check" in Music>Preferences>Playback, 3) Set the correct bitrate/bit depth for your test file in the "Audio MIDI Setup" app (located in User/Applications/Utilities). these steps should do it.
Music on Linux and Mac should play bit perfect. software such as MPD gives you 32bit of accuracy on Linux (via ALSA) and 24 bit accuracy on Mac (via CoreAudio). If not, your setup is wrong.
On my Mac, to pass the Bit Test with VLC I must set "resampling" to "Off" in the advanced settings of VLC. smile
