Topic: Adi-2 FS ADC question
I´m planning to add an Adi-2 FS to my setup.
Is the ADC the same as in the latest Pro FS?
Thank you!
J.
Re: Adi-2 FS ADC question
Basically yes. But the Pro goes one step further and uses 4 channel ADC for stereo, which results in 3 dB better Signal to Noise ratio. The ADC is from the same 'family', and the whole analog input circuit is fully identical, except for the missing +24 dBu option.
Thanks Matthias,
does it also use the SD Sharp setting exclusively?
