Topic: ADI-2 Pro FS R digital out w/o PEQ but with volume control?
Hi all,
I am using a ADI-2 Pro FS R in the following setup/use case:
- Main speakers connected via ADI-2 analog out
- Behringer DCX2496 connected to AES digital out
- Subwoofers connected to Behringer DCX
The separate Behringer DCX2496 is used to delay, equalize and x-over the subs. Both subs are currently running parallel to the mains, using optimized settings.
Obviously both ADI-2 analog out and digital out shall be volume regulated, so I switched DIG OUT SOURCE to DSP/DAC.
Question:
Is it possible (or planned to integrate such option via future firmware upgrade) to assign the ADI-2 PEQs to the analog out only, and the ADI-2 volume control to both the analog and digital outputs? This way, the ADI-2 PEQs could be used to equalize the mains and high pass them at least with 12dB/Oct.
If not possible - has anyone an idea how to optimize my use case with the given hardware?
Thanks, Mark
ADI-2 Pro FS R BE / UFX II
Minidsp SHD
Neumann KH120, KH310, KH810 / Audeze LCD-X
