Topic: Volume on ADI 2 FS
The Volume is stuck on Locked so I cannot use the remote or the volume dial to control volume.
This happens on SPDIF and USB. If I plug in headphones it works fine and the Locked notification turns off. How to fix? Thanks.
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → Volume on ADI 2 FS
Try this : Push and hold the volumen knob for about 3 seconds (2 seconds officially described in the user-manual).
No, tried that a while back. Does nothing.
when you plug in a headphone then all problem is gone ?
Then you can make the speakers louder ?
How about just plug in an adapter, from small headphone plug to big ?
Wiggle the plug in out a few times ?
When I plug in headphones speakers go off as they should and volume knob and remote functions. Also, dB readout replaces Lock notification. Take phones out and volume locked, knob and remote don’t function.
Did you read manual page 22 and 62?
A lot of functions and settings are individually for Main-, Headphones- and IEM-Output.
Yes, after a lot of reading I was able to reconfigure the line out. The manual is superior to most but a little tricky. Thanks, rt
