Topic: Input mix send to usb?
My goal is to use ADC at the end of an analog signal chain to record high quality audio along with video recording on an ios device. I purchased the ADI 2 pro because of its stereo mode, which routes signal to 2 usb channels. ios does not play nice when it detects more than 2 channels of usb audio. The ADI 2 pro works very well in this sense. However, I have 2 separate sound sources and I want to control the mix of the recorded sound rather than hard panning R/L which is the default behavior. I know that there are width controls for the headphone and main outputs, but is it possible to control the mix that gets routed through the usb stereo signal? I am aware that totalmix is not supported and that this is not a recording interface. However I am using it as such because there is a gap in the market for adc with 2 channel usb out. I know the Fireface UCX has a "stereo mode" configurable in the ios app but it does not seem to work (other apps still detect multi channel) and I don't know how the implementation of the UCX's stereo mode differs from the ADI 2 Pro's stereo mode.
