1 (edited by squeakyfrom 2021-04-15 16:46:07)
Topic: [Solved] Fader not moving with baby face
hi there,
i'm using total mix fx 1.60 mac
with a babyface with latest firmware and driver.
OSX 10.9.5
everything was working fine, until today.
Now when i move the big jog dial on the babyface,  the volume gets adjusted as expected,
but the fader in TM is not moving up or down.
not sure why this changed i checked settings and preferences and everything seems to be the way it should be
any help is appreciated!
Re: [Solved] Fader not moving with baby face
Try a total reset in Totalmix ?
3 (edited by squeakyfrom 2021-04-15 16:36:33)
yeah also tried that but it didn't resolve the issue
(and of course a restart of the whole OS)
My Totalmix FX is 1.73.
May be an update of the driver is ready ?
ah i forgot to mention I'm still on OSX 10.9.5
Have you connected any Midi device, a midi keyboard ?
I think you may be confused about the hardware controls. The jog wheel can control input gain for analog inputs, or output level. Please check again. Press the OUT key on the hardware until Ch 1/2 LED is lit. Now the knob controls the fader for AN 1/2 outputs. Turn the knob. Check that the output fader in Totalmix FX bottom row is moving as expected.
Problem solved. thanks for the help guys.
it was, of course, my own stupidity in the end
smile
