waedi wrote:In the USB Fireface settings dialog of the 802 you select clock-mode external adat.
In Totalmix doubleclick on every fader of every hardware output for opening the channel fully.
Then in the menu Options, Options / Store current state into device, you have to store this Totalmix configuration into the device.
Page 46 ff in the user manual stand alone operation.
After this you can disconnect the 802 from the computer and connect the 802 to the Apollo with two toslink cables. The Apollo must have set the clock-mode internal.
In the USB Fireface USB Setting, I can not switch the clock-mode to external ADAT.
When I click on Clock Source in clock mode fireface USB setting I only get from the following ,
-Internal
-Word Clock
-AES
-ADAT 1
-ADAT 2
I currently have it on ADAT 1 ( Sample Rate 44100 HZ, Clock Source: ADAT 1, Current Clock ADAT1 in )
Input Status is
Input Status
World Clock: No Lock
AES: No Clock
ADAT1: Sync 44.1 KHz
ADAT2: No Lock
Does this seem about right. Thanks.
