KaiS wrote:junoman wrote:Will there be ever a 8channel interface with USB, totalmix,
at the quality as ADI2-pro fs ?
If you don’t need all of the home-audio related features, what about the UFX+ ?!
Well, if technical data / measurements is of great importance to him, then the ADI-2 Pro FS R BE scores better. You also have four reference levels for AD and DA.
The question is whether this litte measurable "difference" is actually noticeable in any form in practice. But he would have to and should indeed try it out, because that would otherwise be a very nice solution to consider the UFX+.
However, it is not known whether he is not already using other devices as his main recording interface, but in all likelihood they could well be replaced with the UFX+ nicely as well (probably).
And then the combination of UFX+ and ADI-2 Pro FS R BE would be very recommendable to get some of the ADI-2 Pro specific features into the setup for the main monitor / headphones.
This brings me to the following ideas:
1. UFX+ and ADI-2 Pro FS in combination
Then you have a very good and flexible combination of products.
Use perhaps the ADI-2 Pro for main phones and main monitors
And then on the UFX+ you have even two more excellent phones outputs, 8x analog I/O, AES, 2xADAT, MADI
The ADI-2 Pro FS R BE you can combine very nicely with the UFX+ like described in this blog article https://www.tonstudio-forum.de/blog/ind … our-Setup/
Or
2. combination of MADI or AVB capable recording interface and either M-1610 or M32-Pro DA ?
Both converter support AVB and MADI and allows in an AVB network the integration of MADI devices.
With those devices you would also have some spare channels.
The DB-25 Tascam plugs could also be helpful depending on your environment whether you work with a patchbay or not.
