Topic: ADI-2 Pro FS R Black Edition A-A. A-D. A+A-D?
I am wondering if the 'ADI-2 Pro FS R Black Edition' may fit my needs - or if there is some other RME bit if kit which would be better suited?
I have been using an ADI2 DAC FS as a preamp effectively with the USB input driving my amp.
I now wish to add an analog input in the form of a balanced XLR source.
I use Ableton to make music with Native Instruments kit (very good) but the XLR source is purely analog.
So I want to potentially do three things I think;
1. Monitor the main ANALOG INPUTS via MAIN OUTPUTS in real time with volume control of the output/input.
2. Also at the same time record the ANALOG INPUTS via/TO USB.
3. Also at the same time as the above play back via/FROM USB to MAIN OUTPUTS
I get the impression that the 'ADI-2 Pro FS R Black Edition' could do this all but should I look at some other RME devices as well?
I have an ADI-2 DAC FS at the moment which is really great for playback from ROON and Ableton.
BR,
Milo
