Topic: "adi-2 dac fs" and "adam a5x"
(i read a lot, and i tried a lot before registering in this forum and creating this topic)
my setup is:
1) adam a5x (the volume is possible from -∞ to 14dB) (i always keep the very middle value: 0dB)
2) adi-2 dac fs (4490) (SW version is 12/2019) (connected to a5x via RCA)
3) i use the optical connection (cable is "klotz") (the system board is "ASUS P9X79 WS", its audio is ALC898)
4) i don't use the usb connection (there are no drivers from RME for my OS: win server 2003)
5) i don't use the coaxial connection (and most likely, i will never use it)
6) currently i don't have any headphones (and i don't plan to buy them, at least in the near future)
7) i listen to the music in foobar (its version is very old: 0.9.6.4) (greatly customized to my taste)
- output device: "DS: Realtek HD Audio output" (another option is available: "KS: Realtek HD Audio output")
- buffer length (recommended 1000-2000 ms): 1000 ms
- output data format: 24-bit (32-bit is also available)
- dither: no
active DSPs: [empty list]
configured virtual asio devices: [empty list]
playback:
- volume control: always total maximum
- replay gain (source mode): none
- replay gain (processing): none
- preamp (with RG info): ±0.0dB (89.0dB)
- preamp (without RG info): ±0.0dB
8) i don't have any asio-related stuff
9) i also use the "audition (3.0.1)" program (quite often)
10) the sound properties of the OS:
- "master volume" is always enabled (but always at 0%)
- "wave" is always enabled
(it's the only place where i adjust the volume when listening to music: i have a convenient ahk-script for it)
- "SPDIF" is always enabled (but locked by the OS at ~75% of volume)
- other columns (like SW Synth, Mic Volume...) are either disabled or completely blocked by the OS
11) currently in the "adi-2 dac fs" i have these settings:
- reference level: +13 dBu
i tried the other 3 options: -5 is awful, +1 is better, +7 is normal, +13 seems to be the best
- volume: 0 dB
i got used to 0 dB in the "adam a5x", so i guess the 0 dB is the best option in "adi-2 dac fs" as well (i may be wrong)
- auto ref level: off
i'm definitely not going to use this option because:
"this technique includes switching of hardware elements ... and is therefore not free of click noise"
(while using the DAC, any kinds of auto-clicks are entirely unacceptable to me)
- width: 1.00 (is it the optimal choice?)
- mono, m/s-proc, polarity, crossfeed, de-emphasis, dual EQ, lock volume, mute, dim, loudness: OFF
should i enable the "lock volume"?
- DA filter: SD sharp
i'm not considering the 3 of 5 filters because:
"Slow and NOS filters cause much more aliasing into the audio band and out-of-band noise than Sharp filters"
should i use the "sharp" filter? (instead of the default "SD sharp" filter)
- balance: <c>
- eq enable: off (i'm not going to use the eq)
- bass/treble: it is currently off (i haven't decided conclusively what to do with it)
- dsd: not going to use it at all
- sample rate: it is always locked at 48k (even when i listen to 24/192-file). is it normal?
- bit: it is always displaying the "16" value (even when i listen to 24/192-file). is it normal?
- state overview: "sync" and "cons" are always displayed
12) i didn't knew it for sure, but now i have in my memory this info:
- SPDIF is limited to 24 bit
- SPDIF is limited to 192 kHz
is it correct? is the 24/192 my absolute maximum? (using the optical connection)
13) is it correct that those test-files (9 wav) are not usable for me?
i'm asking because: i have those files, i tried to play them, and i saw nothing related to them in the screen of "adi-2 dac fs"
14) is there a tiniest sense to substitute my RCA with XLR?
- considering the fact that the current "+13 dBu" value already gives the volume with a very (very) high reserve
- considering the fact that i would like to keep the volume (of "adi-2 dac fs") at 0 dB
15) i'm not good in understanding many sound-aspects, but if i'm not mistaken: the higher SNR - the better
during my experiments with the "adi-2 dac fs": in all cases i don't hear any noise or distortion
while the dynamic range is what really important to me
- i don't like the numerous remasters very much
- i like a lot the sounding of CD's from 1982 to ~1997
- at the same time i hate everything related to vinyl-records, sorry (especially when there is no digital alternative at all)
(clicks and other various sound-defects destroy every good thing about vinyl, and make it a garbage)
16) i know that +13 dBu equals 3.46 V
in my case (using the "adam a5x" speakers):
- is it safe to use: +13dBu (rca) and 0 dB volume?
- is it safe to use: +13dBu (xlr) and 0 dB volume?
- is it safe to use: +13dBu (rca) (with bass gain 6.0 dB) and 0 dB volume?
- is it safe to use: +13dBu (xlr) (with bass gain 6.0 dB) and 0 dB volume?
17) just a few additional notes:
- the remote control (for the "adi-2 dac fs") is not in use (i don't need it)
- after this very initial period of time ends, "adi-2 dac fs" will be placed away (out of my sight)
(so all its encoders/knobs/screen will not be in use as well)
please answer my questions if you have the time, the knowledge, and if you're in the mood
