ramses wrote:On UFX+ only ADAT 2 can be set to support optical SPDIF via RME driver settings dialog.
When using the SPDIF in @UFX+, do you happen to know the best way for the clocking issues involved? I have a consumer device (Bluetooth receiver) with optical SPDIF output, but without inputs for external clocking. UFX+ does probably no sample rate conversion at this input - so, does the whole system need to run as slave to a 50€ Bluetooth receiver? Help is much appreciated, thanks!
MADIface(s) Pro, UFX+, MADI Router
Mac mini Intel, iPad Air 2020
ProTools, Hindenburg
