Topic: DSD file playback issue.
Hello:
I'm using a SMSL SD-9 hifi music player with an external HDD with all my music. The SMSL is plugged into my adi-2 FS through the coax line.
When I play a DSD file the adi-2 FS doesn't turn cyan color to let you know it's playing a DSD file. In the SMSL I have the DSD option set to output DSD file in DoP through the coax.. I have other options for DSD output ( D2P, DoP or DSD native) I know I can't do native unless I use the I2S or USB outputs so since I'm using the coax I thought DoP was the right choice but I'm not sure if the adi-2 FS can read a DSD file through coax.. Can anyone help explain this to me?
Thank you for your time.
