Topic: ADI-2 Pro FS & ASIO SPDIF 6 SR issue (current lastes FW & Driver)
- Have Opto Out on BF as 44.1kHz and connected to ADI-2 Pro fs
- Adi-2 Pro fs Spo shows 44.1kHz what is OK
- Clock SRC SPDIF & SR 44.1kHz
- ADI USB & Multichannel mode
.... sample using ASIO on SPDIF channels, as from old settings using with 48kHz (where App as the master and send to ASIO with set sample rate command)
... samples are distorted and no complains from the RME ASIO driver where 44.1kHz & 48kHz do not mach
... in other words SPDIF input should be checked (as in the old days), whether SR of clock source could be matched
