john34 wrote:Recently got my adi pro and I love how it sounds. Today I noticed some weird behavior. When listening over analog input to an LP I changed by chance from a 16 bit 44khz file to a 24 96 file on the simultaneously connected squeezebox touch (usb). The music played over analog input paused for a fraction of a second. I am using newest fw. The glitch is reproducible.
This is normal behavior.
You changed ADI-2 Pro’s samplerate, visible in the main display down right.
The internal reconfiguration needs a few ms.
ADI-2 Pro’s clock usually (the exact behavior depends on ADI-2 Pro’s selected “Mode”, see manual page 36ff) follows USB as long as it’s connected and selected as source.
To avoid that you could change ADI-2’s clock source to internal by unplugging USB or switch off squeezebox.
Or just play this 96 kHz file for a moment to make ADI-2 run at 96 kHz
