Topic: USB Player Pro and DSD Direct
Greetings,
My Pro FS R BE has the following settings
1. Direct DSD 1/2 ON
2. DSD Detection ON
3. CC-mode Stereo
When playing DSD64 track from USB Player Pro from Android phone, I could adjust the volume from my amp. I thought in Direct DSD one can't adjust the volume? So it's playing using DOP?
The DAC output connects to the amp using XLR (from DAC) to RCA (to amp).
According to USB Player Pro web site, it does support DSD natively.
Support for DSD
if PCM audio is not enough
When you have a DAC capable of DSD (Direct Stream Digital), you can even play DSD (.dsf/.dff) files natively, providing a 1-bit digital stream (over PCM using the DoP protocol) like the Super Audio CD of past times! This format is now becoming increasingly more popular among audiophiles surpassing the quality of PCM audio streams. USB Audio Player PRO will convert the DSD stream to PCM if your DAC does not support DSD natively.
