Topic: analog input 1 meter jump on SR change
Posting this here in case it is useful, but I noticed while changing sample rates from either 176.4 or 192 to either 44.1 or 48khz,
roughly 1/2 the time, analog input 1 meter will jump to clipping briefly. There is no audible output (as the outputs are muted during the change I think?) Tested in both Balanced mode and regular mode, and i'm currently in multi-channel mode (have not tested in stereo mode)
link to video of it happening:
https://www.dropbox.com/s/xvic16sfavqsx … 7.MOV?dl=0
note: I'm changing the sample rate via the audio midi setup window, and I wrote a soundflow script to do it from my stream deck (and it's conveniently in front of my ADI-2 Pro, which made capturing the video easy)
Re: analog input 1 meter jump on SR change
That's a level meter glitch, will be fixed.
