Topic: Parametric EQ + B/T Settings
Could some please explain to me:
I've set up my 5 band EQ and saved eg: LCD-2, but if I try to save B/T settings as a 6/7 band eq it doesn't save under that headphone setting.
Is this not a feature as they have to be set on the fly? Or am I doing it wrong?
2nd Question
When I try and load other headphone profiles, sometimes they appear as they were set by me and sometimes they don't
3rd Question
What is the correct way to save profiles? Through Setup or through EQ?
Please don't direct me to the manual. I've read it a couple of times. I'm an old bugger, but my comprehension is getting rusty as are my joints. Cheers All and Stay Safe
I think, therefore I am!
2 (edited by KaiS 2021-08-31 10:57:16)
Re: Parametric EQ + B/T Settings
You can save the settings of the 5 band EQ into one of the 20 “Preset” location.
Or you save complete device configurations, including everything, into one of the 9 “Setup” storage locations.
This saves and recalls ALL device settings, even the B/T function that is independent from 5 Band EQ.
If you change a setting you need to actively store it again. There is no auto-storage.
Don’t forget to name the Presets or Setups.
That makes sense.
Thanks for clearing that up for me
Much Appreciated
