Topic: Fireface USB Driver v3.25 installation
Hi, I can't install Fireface USB Driver successfully on my MacBook (Big Sur 11.6).
After finishing all the Fireface USB.pkg installation steps, I can't find these two files in their specific path
/System/Library/Extensions/FirefaceUSB.kext
/Users/username/Library/Preferences/de.rme-audio.TotalmixFX.plist
And the Totalmix tool cannot be opened. (But FireFace USB setting can be opened)
I've tried installing the package above 10 times, and have tried v3.24, v3.25, v3.26.
Could you help on this, thank you!
Re: Fireface USB Driver v3.25 installation
What software version number is Totalmix ?
Maybe difficult to find out, if he can't open the tool..
4 (edited by waedi 2021-10-04 10:24:36)
The application folder where the application is in is the place to look.
Every application has a version number there.
It should be : 1.74 beta 3 MAC OS X
You also can download the 1.74 separat from here and replace the old by drag and drop.
https://www.rme-audio.de/downloads/tmfx_174_mac.zip
5 (edited by ramses 2021-10-04 10:41:10)
EDIT:
Maybe the issue is related to this ?
https://forum.rme-audio.de/viewtopic.ph … 60#p168560
Or that:
https://forum.rme-audio.de/viewtopic.php?id=33372
Check also here:
EN: https://www.rme-audio.de/rme-macos.html
DE: https://www.rme-audio.de/rme-treiber-macos.html
Thanks everyone, for v3.2ˊ, the totalmix version is 1.74 MAC OS X (1).
I found my RMEFirefaceUSB.kext is located at /Library/Extensions rather than /System/Library/Extensions. Is it the correct path?
8 (edited by ramses 2021-10-05 05:38:48)
Did you check the links that I provided to you in my post 5 of this thread ?
What about this ? It sounds to me as if this could be the issue...
https://forum.rme-audio.de/viewtopic.ph … 11#p172511
and here the official RME document to that topic: https://www.rme-audio.de/rme-macos.html
Yes, I've tried those methods, thank you ramres.
And I found that Totalmix always show this Soundcheck stuff every time I finished reinstallation.
Does it mean there is something I miss to clean before I reinstall the package?
https://drive.google.com/file/d/1QqMQQJ … sp=sharing
10 (edited by ramses 2021-10-05 06:35:49)
Did you read this information at the end of the official RME document (https://www.rme-audio.de/rme-macos.html) ?
"For more information, please also take a look at the following RME forum post:
Definitive solution for macOS "driver not loaded" Security problems
https://forum.rme-audio.de/viewtopic.php?id=30462
If this doesn't help, best send an e-mail to RME support, maybe they can support you with a remote session.
