Topic: disconnected Babface Pro, reconnected, now computer doesn't see it
I'm on a 2020 Mac Mini, OS Big Sur 11.6. I was temporarily using a Fractal Audio FM3 as my interface. When I reconnected the Babyface Pro, the computer no longer sees it. This was October 6th, 2021. I noticed that there were new drivers and I installed them. The security/privacy permission window popped up and I gave permission and restarted. The Babyface is still not seen. I reinstalled the drivers several more times (but no permissions window popped up) and restarted several times. Should I follow the procedure that I've read about on this forum to reboot in recovery mode and run the recommended terminal command?
