danevaz wrote:Thanks for the response Ramses. Option 2 is exactly what I had in mind.
I'm not sure about option 1 as I am on WIN10 and as far as I know, in Windows, a DAW can only reference one ASIO interface at a time.
But I'll figure it out.
Danny
No, it's like this: "an application/DAW can only load one audio / ASIO driver".
But the application can access all devices that are connected to the computer and are supported by the driver.
For exampe the following RME driver support the following devices:
- old usb driver: Fireface UFX, 802, UCX/UCX II, UC und Babyface/Pro/FS
- newer MADIface driver: MADIface XT/USB/Pro, Fireface UFX+/UFX II, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, Digiface USB
Thats theoretically a lot of device and also multiple of it, that an ASIO driver can support, IF the computer can handle that many audio channels as all channels are being transferred no matter if they are used (with one exception that I mentioned already, the HDSPe MADI FX with it's special resource optimizing driver).
You just have to make sure that the devices are synchronised via digital connections or word clock (or a mixture of both) and use the same sample rate and ASIO buffersize, the latter so that sample can be recorded accurately (see RME driver settings).
This works fine, I already had it running here with two UFX+ and one ADI-2 Pro.
Matthias Carstens once said here in the forum that RME tests its drivers up to a maximum of three devices, e.g. 3x RayDAT, but that no upper limit is coded in the driver. It is often the case that hardly any more ports are needed or that there are not enough free PCI/PCIe sockets or unshared USB ports or that the PC cannot support more ports or transfer them without interruption. For example, due to higher DPC latencies (depending on the drivers) and also depending on the sample rate and ASIO buffer size.
