Topic: how to trim power amp?
A misc. question came up.
Say that I'd use a (for this case RME DAC) to send signal in a power amp that is way overpowered for my room and/or ears (but brings a fine balanced sound). I would thus have to limit the DAC output or better said the balanced line level to the amp to reach my desired listening levels.
I want NO risk of software/user/other errors resulting in a possible max output level into the amp.
As such I think of a hardware solution. I know there are DAC with analog volume control that would work reliable and never crash, but are there other options? (e.g. I thought of a passive balanced monitor level controller)
What are your thoughts or experiences?
ADI2, Digiface, ARC
Re: how to trim power amp?
Hi, have a look here:
https://forum.rme-audio.de/viewtopic.php?id=25399
Jakub
3 (edited by ramses 2022-02-05 11:16:39)
See also this posting:
https://forum.rme-audio.de/viewtopic.ph … 66#p182766
This one is not too expenside and covers a good switchable range up to -30 dB:
https://www.thomann.de/gb/jts_ma_123.htm
Note: you need ~18 cm behind your power amp, 10cm for the attenuator itself and approx ~8cm for a normal, straight XLR cable not to bend it too much.
You can save a few cm by using an angled XLR plug, like e.g. these from Neutrik:
https://www.neutrik.com/en/neutrik/prod … /rx-series
Thanks for recommending!
As note to self: I've checked my amp @ 0db gain and for comfortable listening I trim -50dB in Totalmix.
ADI2, Digiface, ARC
