Topic: Using ADI-2 DAC FS with Antelope Orion Studio Synergy Core
I just registered to this forum. Nice to be here.
I just bought a ADI-2 DAC FS and would like to use it with my Antelope audio interface.
I am into mixing and mastering, no recording with microphones and instruments. Only virtual instruments within DAW.
I am on Mac, speakers are PMC TwoTwo 6.
After reading on the ADI, I thought that I could benefit from it's great DA conversion if I add it to my actual system.
Anyone would share some knowledge on how to use ADI with my audio interface?
Thank you all.
2 (edited by KaiS 2022-02-24 10:06:51)
Re: Using ADI-2 DAC FS with Antelope Orion Studio Synergy Core
Connect ADI-2 to the SPDIF- or ADAT-out of the Antelope Orion Studio Synergy Core.
Then connect headphones and maybe your speakers to ADI-2.
Route the monitor outs of your DAW to Antelope’s SPDIF- (ADAT-) out.
@KaiS
Thank you very much for your answer.
I will receive the ADI sometime next week.
I will be back here to report if all went well and also if I gained in sound quality using the ADI converter instead of Antelope's.
Best regards
This unit is simply amazing!
I used it as a USB interface since I don't record. Only mixing and mastering.
I wanted truth and transparency when mixing. I found it with the ADI-2 DAC FS
Tks
I too have an Orion Studio and am interested in knowing more about your experience with the ADI-2 DAC FS.
Have you tried combing the two interfaces over S/PDIF?
Would you say RME is outperforming Antelope's monitor outputs?
Thanks!
