Babaluma wrote:I tried the Oratory curve with my HD600s on the 2/4 yesterday, and hated it. Promptly disabled.
Oratory has done good work measuring myriad of headphones, kudos to him, but his EQ-filter sets are in many headphone model´s cases laboratory exam -looking extreme fine-tunings, not practical i.e. reproducible in real use. For many headphone models he wastes a lot of filters for very narrow Q-value notches and tiny 0,5 - 2 dB gains in high treble, for example. He apparently doesn´t take into account that almost all headphones begin to exhibit enlargening amount of variance between head insertions toward high frequencies.
Not a chance they to be reproducible in real use scenarios, where users put their headphones on and take them off for every listening session.
Rtings for example has covered this, as Frequency Response Consistency -section, in their headphone reviews. HD 600 in question, for example, goes quite unconcistent above 5 kHz. So applying EQ-filters on them goes quite lottery i.e. is not reasonable anymore.
https://www.rtings.com/headphones/revie … ser/hd-600
In using EQ, concentrating the things that actually benefit from correction, is essential. In Sennheiser HD 600´s case, which happens to be about worlds most neutral stock headphone already, the beneficial target areas for EQ are
-sub-bass -lift. This is the most audible thing for this trusty old workhorse to get its set updated.
-upper bass / low middle little shave -down
-1.3 kHz -area little shave -down
-3.2 kHz -spike/resonance shave -down
From Oratory several Sennheiser HD 600 -curves, the recommended one is his Optimum HiFi Curve, first four filters. Rest of his curves, also that "RME ADI-2" -one, are those Harman target -bass boost curves.
Harman target curves have impressive oomph-oomph for laymans etc. hasty amateur listeners, but have not much left to do with neutral sound reproduction anymore. Their major level core-problem is, that this +5 dB from neutral lifted bass doesn´t work, if source material already has hefty bass. Result is bad listening hangover and fast resetting of those EQ-settings. If listener is not total rubberhead etc boom-boom-boom -seeker, that is.
This Optimum HiFi Curve -one instead, is applicable
https://www.reddit.com/r/oratory1990/wi … f_presets/
HD600/Optimum HiFi Curve
https://www.dropbox.com/s/ygs3wfnj4ntgm … 9.pdf?dl=0
Only four (4) first filters are needed/applicable. Rest goes that audio-engineer-doing-lab-exam -department, in that filter set too.
This filter set, put in in ADI´s EQ, would look like about this:
-B1: +6.0 dB, 25 Hz, Q 0.7, filter type: Shelf
-B2: -2.0 dB, 150 Hz, Q 0.5. Filter gain re-evaluated by cross-comparing (and listening) to different HD 600 -measurement sources.
-B3: -2.0 dB, 1.33 kHz, Q 1.4
-B4: -3.0 dB, 3.2 kHz, Q 2.2
Thats it. With this EQ, HD 600 is now updated to kick ass. Again, the next couple of decades.
