Topic: ADI-2 Pro input selection for digital output mode
I have been using the digital output (spdif coax) of the ADI-2 pro, with usb (from pc) and spdif coax (for streamer) as digital inputs, but the part that I cannot figure out is how do I explicitly select or switch the input between usb and spdif. The problem is that current automatic switching doesn't switch to usb from spdif coax if I have been using spdif coax and want to start using usb as source (or vice versa). Is there any specific mode, setting I can use to make inpout selection possible using the remote input selection?
Thanks,
Dehati
