Topic: Factory reset
I wanted to do a factory reset on my new adi2-pro fs BE. I followed the manual.
  • Switched the device off (red ring)
  • Unplugged the USB cable
  • Hold encoder 1, 2 and Volume
  • Switched on the device and hold the encoders untl a message shows
Showing the message is the problem: according to the manual there would be a message 'reset done'. Not in this case. After a while there is a message 'Preamp activate (which is factory default without USB connected).
How can I be sure that the factory reset is complete and done.
Before all this I did a firmware update from 112 to 116.
Re: Factory reset
It's the VOL button you need to press not the volume encoder.
3 (edited by bejoro 2022-07-19 10:36:18)
Re: Factory reset
Did you press the button "VOL" or the volume knob?
You have to hold also the button called "VOL".
EDIT: Mark was a bit faster. :-)
Warm regards,
Bernhard Rother
enjoy-audio.de
Re: Factory reset
Oh wow! That was good information.
Stupid that I made this mistake. Indeed I pressed the Volume know and not the Volume button.
Thank you both! And what a quick reply.
Johan
