Topic: RME ADI 2 Pro fs R BE act as Active Crossover for 2:2 system
Dear all
i have a question before buying my second RME. I would like to use the PRO acting as a room correction and a Active Crossover for my 2.2 system (two mains and two sub). Is it possible to do that using also the EQ feature inside the RME? which are the correct path? Is it describe in the owner manual?
Thank you in advance.
Re: RME ADI 2 Pro fs R BE act as Active Crossover for 2:2 system
It‘s doable, but not very flexible or user-friedly.
If your subs have built-in filters it’s better to use those.
If you tell the models of subs and mains I can give you more assistance.
Dear kais
these are mine and they have regolable filter on board
https://www.bkelec.com/HiFi/Sub_Woofers … %201-1.pdf
4 (edited by KaiS 2022-09-24 17:21:01)
smolteni wrote:
Dear kais
This server is down, link doesn’t work.
Anyway, for a valid proposal I would need to know all your related components.
