Topic: UFX+ and Digiface USB combined - what's the best option on M1 Mac
Hi
I am using Ableton Live on a M1 Macbook Pro.
The setup consists of 1 x UFX+ interface and 2 x Mytek 8X192 converters connected to ADAT i/o on UFX+.
One of the Myteks is set as the Master clock source for the whole setup, and it has to be this way because Myteks dislike external clocking. BNC cables are currently used for slaving. The setup runs at 48kHz so only a single pair of ADAT i/o's on Mytek units are used in connection with the UFX+.
I again need to add 8 more converter channels via ADAT, and unfortunately I've got no ADAT I/O left on the UFX+. I am looking at another 8X192 for this.
The available Digiface USB I've also got could provide me with additional ADAT ports for 8 more ADDA channels. However, with Mytek still needing to be the Master, and the Digiface USB has no other means of being physically slaved to Mytek, I am wondering how to best connect all this (?)
I read somewhere that I need to use aggregate option in the MacOS to join the UFX+ and Digiface USB into a "single" unit. I know that there's a latency increase when drift offsetting in the computer is used, so I am considering other options.
Can I maybe use a pair of ADAT i/o ports on Digiface USB to slave it to the unused pair of ADAT i/o ports on the Mytek Master?
Also, is there a better way to connect all this?
Thanks!
