Topic: ADI-2 DAC + AUDEZE LCD 5 ground noise issue
hello everyone,
i am experiencing a noise/grounding noise issue with my combination of the DAC FS and the Audeze LCD 5.
When i wear the LCD 5 headphones and my ear touches the apparently conductive part of the speaker, i hear a ground buzz in the corresponding side and also on both sides, if both ears touch the inside.
This also happens if the DAC is turned off but connected to power.
The noise disappears if I;
- touch the shell of the headphones plug plugged into the DAC
- touch a screw or a metal part of the DAC
- touch the metal housing of my macbook air connected via usb
- connect the power adapter of the macbook.
btw, This did not happen when i tested the headphones in the shop, so i guess that the buzz isnt supposed to be there if my ear touches anything.
Any ideas what exactly is going on here and how to fix it?
Best regards, alex
