Topic: feature request: Poti Level Markers or recallable levels
Is it possible to implement recallable level settings or to mark a specific gain value?
I often mix with different calibrated volumes e.g. -23 LUFS, -27 LUFS, or with -16LUFS or according to the K-System. And would like to have Volume markers shown on the display that I can set myself.
2 (edited by KaiS 2022-11-08 13:32:15)
Re: feature request: Poti Level Markers or recallable levels
You can store and use a “Setup” for each level, and name them accordingly.
If you enable “ Load Volume with Setup” you get what you want.
Read manual page 29 (DAC) or 30 (Pro).
Loading certain “Setups” can be assigned to a button push.
Read manual page 26 (DAC) or 28 (Pro).
Watch out:
The “Remap key” configuration is part of each individual “Setup” and needs to be set for each individual “Setup”.
This can be used to toggle through 2 or more Setups with one single button.
Works like this:
As the button assignment isn’t global, but part of each “Setup”, you can even have different assignments to the same button in each Setup - a nice feature that we can use for the following:
Choose ONE single button that you usually don’t need.
In Setup 1 assign: “load Setup 2”
In Setup 2 assign: “load Setup 1”
Now this single button toggles between both Setups.
This method can be extended to load even more Setups if needed, like:
In Setup 2 assign: “load Setup 3”
In Setup 3 assign: “load Setup 4”
In Setup 4 assign: “load Setup 1”
Now the single button circles through Setup 1-4, clever, isn’t it?!
As for loading Setups ADI-2 asks for confirmation, a double-push is needed to execute the load.
Holding the button more than 1s, the button‘s original function is available.
Therefore I typically assign the SETUP button to load Setups – sic!
nice! I would never have thought of that.
