Topic: Dark volume screen ADI2 Pro FS R
I upgraded my ADI2 DAC FS to an ADI2 Pro FS R in order to connect a 4 channel digital room- correction device to it.
For this application I need to run rear main outputs 1/2 and front PH3/4 at the same volume levels and with linked (dual volume) - both works flawlessly.
However the default dark volume screen always does show the linked and in my case identical volumes for CH1/2 and CH3/4.
Would it be possible with one of the next firmware updates to show only 1 volume for both outputs under the following conditions:
- Dual volume is active and
- Ch1/2 and 3/4 are set to the same volume level
Best regards and thanks!
