1 (edited by wowchina.wcj 2022-12-21 16:48:04)
Topic: ADI-2 DAC The latest driver is faulty!
Hello Sir:
regarding the "ADI-2 DAC fs", there is a serious bug in the win10-driver(Ver 0.9.804.0) you just released today on the 20th: The playback software I use is foobar2000. I found that after upgrading to this version of the driver, when I press the pause or stop button, there will be an echo in the speaker. Under normal circumstances, the sound should stop immediately.
(complement): And I found that this latest version of the WIN driver has another serious problem: When I switch between music files with different sampling rates, every time I switch to a file with a different sampling rate, I find that the CPU utilization of the computer will remain high in the around first ten seconds , especially there is a process called "windows audio endpoint builder", which has a particularly high CPU usage.
please as soon as possible fix this error. thanks : )
I can't downgrade to the previous version(V:2022-12-1) of the driver now because I have deleted the old version of the driver from the computer. Can you help me? Is it possible to send older versions of drivers to my E-mail "caosgf1314@163.com" ?
thanks.
Also, when you try to install an older driver, windows prevents you from doing so. So how to downgrade to an old driver? Because I don't know how long it will take you guys to fix this issue, maybe even months? I can't wait, so I want to downgrade to an older version until you guys fix this problem.
Please tell me how to downgrade, thanks
The same content as above is also had sent to RME office FACEBOOK page.
......A.Kin from China
Re: ADI-2 DAC The latest driver is faulty!
I observe the same problem
I, too, am experiencing the same symptoms.
4 (edited by Muffin 2022-12-22 09:14:54)
I also have the echo when pausing Foobar2000 and I use the ASIO plugin. By re-installing the driver version 0.9801 I don't have echo when pausing.
I want to downgrade the driver, but that file was deleted by me.
Can someone please send me the old version?
The file name of the old version is -----driver_madiface_win_09801.zip
Can be sent to my email address "caosgf1314@163.com"
thank you very much. : )
..........A.Kin
https://rme-audio.de/downloads/driver_m … _09801.zip
thanks  waedi : )
8
Driver 0.9805 is now on the website, it fixes the non-stop behaviour of version 0.9804.
