Topic: ADI-2 DAC FS - Crackle on 1 channel until warm - could it be the DAC?
Apple Music > iPad 6 15.6.1 > Apple USB-C Digital AV Multiport Adapter > 4 metre usb A to B > ADI-2 DAC Fs v51 > QED Reference Audio 40 Phono to phono interconnects > Musical Fidelity M3Si integrated amplifier in power-amp mode > 2 metres per channel of QED Original speaker cables> Focal Kanta no 1 speakers
Hi all,
My hi-fi set-up has been installed and in use for a good few months with no problems and great sound. The amp and speakers can also take input from my TV system.
In the last couple of days, after watching TV for some time, meaning the amp and speakers are warm, I have changed to listening to my hi fi. This has involved switching the DAC on and the amp over to direct input (so the DAC is the pre-amp and just the amp power-amp circuitry is used). I have then noticed a crackle on the right channel, which isn’t very loud but clearly a problem. However it clears after about 10 minutes. To test to see if the iPad /USB source is the problem, whilst the crackle is evident on the line-out to amp and speakers, I have plugged in my headphones to find there is no crackle from the DAC headphone output. So it seems it might be a fault with the DAC line out circuitry until, perhaps, the DAC warms up.
I need to do some more elimination tests, but wondered if these symptoms struck a chord with anybody?
