Topic: ADI-2 DAC FS How to Switch Enabled Equalizer while running 3xx hz?
I've tried to scour the manual for this, but I've only seen it mention "EQ can still be used with
Analog Input, Main Output 1/2 or Phones Out 3/4, but only one of these", but I can't find how to actually switch. Disabling EQ on 1/2 doesn't allow me to enable it on 3/4. Any help would be much appreciated.
Thank you,
Will
Re: ADI-2 DAC FS How to Switch Enabled Equalizer while running 3xx hz?
You talk about the ADI-2 Pro, not DAC?
https://forum.rme-audio.de/viewtopic.php?id=35897
