maybe this helps, it is slightly more recent, and as a proof of concept sets up 8 channels: https://github.com/Drumfix/avb4linux
The readme revolves around MOTU, so with a similar piece of AVB hardware you may be good to go. I failed in my use case to output 8 Channels from a Mac Mini M1 to a Linux PC, and can't test other scenarios as I don't have a dedicated AVB device.
MacOS seemingly has good out-of-the-box support for AVB and it should find devices on the same physical layer in the Audio MIDI Setup -> Window -> Network Devices dialog, but I have no idea if that is only for the role of Talker or Listener and how to set up either on the Linux PC.
I currently "throw RME hardware" at the problem, with BBF Pro on the Linux and UCX II on the Mac and connect them via ADAT. I'm reluctant to go down the rabbit hole of trying to get years old tutorials to work when there is not even one success report and it looks like it never gained traction aside from specialized hardware.
UCX II, BBF Pro FS, Quadmic II, PCIe HDSPe Multiface II, AIO Pro
