Topic: DIGI 96/8 PAD in G5 PCI-X ?
Hello from France
is the DIGI 96/8 PAD work in a Powermac G5 with PCI-X slots ?
Loxylox
Re: DIGI 96/8 PAD in G5 PCI-X ?
http://www.rme-audio.de/en_support_faq. … ware_alarm
sorry but i'm not realy sure and i prefere to hear from you ...
can i put my digi 96/8 brought the 05.03.2007 in my Powermac G5 / PCI-x version without risk ?
best regards
Loxylox
No, because we can't know how old that card is. You have to look on the PCB for the manufacturing date or tell us the serial number from the barcode.
5 (edited by Loxylox 2007-06-13 00:53:08)
the serial number from the barcode : 22492469
many thanks
best regards
Loxylox
6
That one is Ok.
Hi !
sorry for the delay , i just come back from holidays today.
Thanks for your so good support ;-)
next thing  : i've brought a second hand AEB4-O and i don't know how to plug it in my G5 Powermac
please could you help again ?
best regards
Loxylox
All the info you need is here - including photos of the connections.
https://archiv.rme-audio.de/download/aebxo_e.pdf
Thanks for the link but it don't show how to connect the power supply...
many thanks
Loxylox
Use the floppy disk power connector coming out of your computer power supply. If it's already used or does not reach, use the supplied adapter to connect to one of the drive power leads.
hello !
i get a new DIGI 96/8 PAD so please tell me if this one is ok for my G5 PCI-X
number on the board : 22492826
best regards from France
Loxylox
www.myspace.com/mclox
If the card is new, it is compatible. Is this from Thomann?
Yes new from Thomann
Loxylox
14 (edited by Mikael Adle 2007-07-05 19:15:12)
Similar question:
Would a hammerfall 96/36  work on a MacPro?
serial barcode# 22122211 (Rev 1.5)
Mikael Adle wrote:
Similar question:
Hi Mikael,
Not possible; the 9636 is a PCI card, Mac Pro only has PCI Express slots.
ok, thanks
Hello
pleas tell me if it's possible to put more than one 96/8PAD in my G5.
many thanks
Loxylox
18 (edited by fucanay 2007-11-13 07:53:25)
One more compatibility check please.
RME Digi 96/8 Pro
Serial Number 22105591
19 (edited by chrisnova777 2014-10-24 22:02:41)
hi there
i have a 96/8 card id like to use in my powermac g5 1.8ghz machine (Pci-X)
the number on my barcode is:
22156995
the card does have 2 notches in the pci interface
i think it should be compatible but im not willing to risk destroying the card + my computer without verification from RME
please advise!
i am also interested to know if the mac os x driver supports multi cards in a powermac g5.
thanks
please - i really need a response..
does noone check this forum anymore?? should i write rme directly?
A bit of patience, please. Checking with the factory. Else, mail me a high-res jog of the entire card (both sides).
This card will need a hardware modification for use with a G5.
oh no..
do u still neeed the jpg?
can i perform the hardware modification myself?
i live in canada its hard for me to ship this card to germany??
Daniel?
26
Even if you might be able to do this mod we will not provide any info about it. Because if something is not done correctly your motherboard is fried. And that all for an audio card which has zero value due to its age!
You can send the card in to our US distributor, they can do the mod, but it will cost some money...more than the card is worth, of course...
sorry im writing once more to be sure
22156995 <-- this is my code on my card
are u sure u didnt respond to the code supplied by the guy who posted before me?
is there anyway u can simply publish the code number that it needs to be above? so that we can assess the compatibility on our own without bothering you each time!!!
If not the canadian distributor, Synthax US can do this for you.
Hi Daniel,
Could you please do a compatibility check on my 96/8.
Serial number on the back under the barcode is: 22129913
Thanks, it is much appreciated indeed.
Best,
- MusicWorks
