• Is playback of DSD-files involved in any way?
• Did you do RME Bit Test for the digital signal path (see manual page 101)?
• How many dB is the wrong loudness off to normal, estimated?
• Does the Volume Control display value change (check on ADI-2/4 Pro SE itself), or does the loudness decrease effect happening without this value lowering?
When it happens, check at the device:
• I/O / [current output] / Settings / Auto Ref Level: does it switch on or off by itself?
• I/O / [current output] / Settings / Ref Level: does it change?
• I/O / Analog Input / Settings / …. does the analog’s “RIAA Mode xx dB” value or the “Trim Gain Left/Right x.x dB” values change by themselves?
Take notes of your “normal” settings before, to compare.
1. Power cycle iPad. Not very likely that it helps, but just to be sure.
2. Try an ADI-2 reset:
While powering up, push and hold the VOL button (NOT the VOLUME dial) and Encoder 1, until you see the message: “Reset done“.
User Setups and EQ Presets are not deleted.
Or an ADI-2 full factory reset:
While powering up, push and hold the VOL button (NOT the VOLUME dial) and Encoder 1 and Encoder 2, until you see the message: “Reset done“.
All user Setups and EQ Presets are deleted.
Take notes before, or store them through the Remote App, if you want to keep some.
